NetSuite Assembly build subrecord
Is there a way in integrator.io to create or update an Assembly Build or Work Order completion to populate the inventory detail sub record?
Hi Tim, yes, there are APIs available to add or update an Assembly Build or Work Order. Please let us know if you would like to explore further with our team.
@celigosupport is there a help article I can review for this? I am working on a project where we are trying to send builds from one netsuite to another netsuite account
Hi, @ruthjeter678. We recently added an example of that type, using a WO Build record, to the article “Configure and map NetSuite subrecords.”
It's not exactly what you’re asking for, since it illustrates integrating with fields in JSON paths from an FTP export, though I imagine that the harder procedure happens in the import, as documented there.
We’d love to hear more about your use case and experience with this feature, if it’s something that others can benefit from here or will improve the help topic.
@stephenbrandt maybe you can shed some light on this query of mine,
You have attempted an invalid sublist or line item operation. You are either trying to access a field on a non-existent line or you are trying to add or remove lines from a static sublist
