Assembly Build for Work Order
Hi,
I'm trying to create an assembly build for a Work Order but I cannot link or relate the assembly build to the Work Order. In which field should I pass the internalID of the Work Order so it can link the assembly build to that Work Order?
For Sales Orders I'm using "Created From (InternalId)" field but for Work Orders this field does not exist in the transaction.
Hi @hristinabendeva -
It looks like you're working with our Support team on this. If you get a chance, please post an update here once it is resolved in case someone else has this question.
Thanks,
Kate
Hello,
We found a solution for this issue on the office hour sessions, and they told us when there is no "Created From (InternalId)" field to map to we should use the "celigo_nlobjTransformId" to map the intenalID of the order and "celigo_nlobjTransformType" to map the type of the order in this case "workorder". Here is a picture of the mapping for reference:
I'm so glad to hear the office hours session helped. Thank you very much for posting the solution! I'm sure it will help someone else down the line.
-Kate
Can you specify which record type you are using for the import as Assembly Build doesn't appear in the record type list.
Thanks
