Work Order Support?
Does Integrator IO Support importing and exporting Netsuite Work Orders? It appears that it does not.
Hi @npsadmin, Yes, it does. When setting up your import or export for NetSuite, select a Record Type of Work Order. Let us know if that doesn't solve the problem!
I ran into this issue today and thought I'd update here. Make sure the role you're using has permission to edit work orders! The default role does not.
