Shopify GraphQL bulk queries and mutations
Best Practices for Bulk GraphQL Operations in Integrator.io
I'm looking for guidance on implementing bulk GraphQL queries and mutations efficiently in integrator.io, specifically regarding endpoint usage and workflow optimization.
Main Questions
1. Bulk GraphQL Processing Best Practices
What are the recommended approaches for handling bulk GraphQL queries and mutations in integrator.io?
2. Universal Shopify Connection Capabilities
Does the universal Shopify connection handle the complete bulk operation workflow automatically? Specifically:
  • Submitting bulk queries/mutations
  • Polling for completion status
  • Retrieving final results
3. Endpoint Usage Concerns
I'm concerned about endpoint capacity given our current constraints. Here's my understanding, if we are required to use async helper as the standard setup:
Current Workflow Requirements:
  • Bulk Query Results: Results are returned as JSONL files via https://storage.googleapis.com URLs
  • Bulk Mutations: Require uploading JSONL input files to AWS S3 via HTTP
Endpoint Impact:
If the universal Shopify connection doesn't abstract these operations, I believe we'd need:
  1. Primary Shopify connection endpoint
  2. Universal HTTP connector for Google Cloud Storage (result retrieval)
  3. Universal HTTP connector for AWS S3 (input file uploads for bulkOperationRunMutation)
This would consume 3 endpoints total, and we're already at maximum capacity.
Specific Technical Questions:
  • Are there alternative approaches that would reduce endpoint usage?
  • If abstraction isn't available: Can we request additional endpoints at no additional cost to accommodate the bulk GraphQL workflow requirements?
Any insights or examples would be greatly appreciated!
You can set this up with only 1 endpoint. You still create a Google APIs connection with no authentication, but since it is only used inside the async helper it does not count as an additional endpoint.
Prerequisites
  • Shopify GraphQL connection
  • Google APIs connection with no authentication (used by the async helper to fetch the JSONL results)
Step 1. Start the bulk job
  • Create an export with an async helper.
  • First request starts the bulk job.
mutation {
  bulkOperationRunQuery(
   query: """
      products {
        edges {
          node {
            id
            title
    bulkOperation { id status }
    userErrors { field message }
Step 2. Poll for completion
  • The async helper polls until the job completes, then reads status and URLs.
  node(id: "{{data.id}}") {
    ... on BulkOperation {
      id
      status
      errorCode
      objectCount
      url
      partialDataUrl
      createdAt
Step 3. Fetch the results with the Google APIs connection
  • Use the returned url.
  • If you need to trim the signed URL before use, here is the helper you showed:
{{{substring data.statusRes.url 30}}}
Step 4. Parse the JSONL into records
  • Each line is one JSON object. Convert each line to an object before saving.
  let output = [];
  for (let d of options.data) {
    output.push(JSON.parse(d.Column0));
  return {
    data: output,
    errors: options.errors,
    abort: false,
    newErrorsAndRetryData: []
Reference on parsing JSONL in Celigo
Flow ZIP
68b0dfaf09707f2d155abf41.zip (6.6 KB)
Video reference
How to attach the preSavePage script to the result export of the async helper:
Thanks Tyler,
I have followed the instructions, but when I switch onto the Google connection, it still prompts me that I have reached my maximum endpoints. See screenshot.
Very odd. I'd request 1 additional endpoint from your account manager then.
