Possible to update NetSuite Transaction with specific form?
I've been struggling trying to figure out how to tell IIO to use a specific Transaction from when updating NetSuite records. It's important because there are mandatory fields that are blank but I still need to be able to update the record. To achieve this I'm trying to use a common SuiteScript pattern where you use a purpose built form with the problematic fields hidden. This then allows updating the record without getting caught up in the mandatory data issue.
I've added Import Mapping for Custom Form (InternalId) using string and number literal values but it's not working, I'm still getting the blank mandatory field errors.
Does anyone know of a way to achieve this other than making the form preferred for the Role IO is using?
Hi @steveklett -
Thanks for posting this. I've brought it to the attention of some folks internally and we will get back to you soon.
Kate
Any update on this ticket?
I am trying to update an item record with a custom form, since my default form has mandatory fields I do not have the data for.
