NetSuite Journal Entry Mapping
Totally frustrated, after days of trial and error I am no closer to mapping a simple .csv file to a NetSuite Journal Entry.
There are examples for mapping parent / line in journal entries, but not a specific Transform examples.
Can't get this across the goal line.
some specifics would help. What errors are you getting? What are you attempting to transform?
@ronswanson - I just noticed your post appeared under our "Welcome" topic so I moved it to the Celigo integrator.io forum where it will get more visibility. However, I also suggest you open a ticket with Support right away if you're continuing to face this issue so that they can look at your .csv data and help you.
Thanks. I happen to see the Office Hours yesterday and was able to visit with the moderators on the issue.
It is working now.
Thank You.
