Possible to update NetSuite Transaction with specific form?
I've been struggling trying to figure out how to tell IIO to use a specific Transaction from when updating NetSuite records. It's important because there are mandatory fields that are blank but I still need to be able to update the record. To achieve this I'm trying to use a common SuiteScript pattern where you use a purpose built form with the problematic fields hidden. This then allows updating the record without getting caught up in the mandatory data issue.
I've added Import Mapping for Custom Form (InternalId) using string and number literal values but it's not working, I'm still getting the blank mandatory field errors.
Does anyone know of a way to achieve this other than making the form preferred for the Role IO is using?
Hello Steve,
Theoretically, it should work out of the box. Can you please create a support ticket so that team can look into it in detail?
Regards,
Akhilesh Goyal
