Hey,
I have been trying to update custom segment field on Job record using an Import. There is no errors and other fields are updating correctly except the custom segment. What could be the possible reason?
Can you share some screenshots of your mappings and import setup?
@anithabanothu was able to update custom segments on a job record in our environment. It would be helpful to see your setup to determine if anything is amiss.
Hi @Kshitij_Gupta
Apologies for the delayed response, and thank you for your patience. I’ve just tested the same case on my end, and everything appears to be working as expected.
To help us investigate further, could you please raise a support ticket with additional details—particularly around the flow configuration? This will enable us to better understand and debug the issue.
Thank you again
Hello,
I raised a case for this, and the team helped me resolve that. The issue was some outdated configuration in mapping. As soon as the field was removed and added again, it started working correctly.
Thank you so much for looking into this.
