Lookup evaluation error
While trying to create a transaction record in NetSuite with greater than 300 line item having dynamic lookups for the line item mappings can give the following errors:
  • NetSuite error: script execution usage limit exceeded
  • IO error: Failed to evaluate lookup
Do the following to resolve:
  • Reduce the dynamic lookup count in mappings/import by creating new export lookup for the same record type used in dynamic lookup.
  • Modify mapping configuration to convert dynamic lookup to static lookup.
