I want to transform an Invoice record to create a payment record.
Hello Jerome, did you end up finding the solution? that would be great if you could shed some insight on this topic, and I need to do something similar!
Hi @damienpinot,
Thanks for letting us know you're looking to solve the same problem! @jeromemorden - did you find a good solution for this yet with support? I've shared both of your questions with our PM team and will get back to you.
Hi @damienpinot and @jeromemorden - We've recently launched Celigo University and it has a great learning path. If you're still stuck, our integration experts are available every Tuesday and Thursday during Office Hours.
Hi All,
Is there a solution to this?
Thanks!
Hello hello :)
The solution involves using 'celigo_nlobjTransformType' & 'celigo_nlobjTransformId' in the mapping when creating the Customer Payment. See the screenshots below for details of an example which has been tested and verified.
Flow
Export Step
Import Step
Import Step : Mapping
Kind Regards,
Adel
Is the example from @adelhaider valid?
Hi @jonureta and @steveklett
I have just built and tested the solution and modified my post above to reflect the changes.
