Connection debugger only displays erroneous flows?
Is it the case that the connection debugger will only contain data from flows when an error has occurred? That seems to be what I'm experiencing. I run my flow and it finishes in a "completed" (successful) state and yet on the "import" side of my flow I don't see the data I expect, and have no way of seeing the request and response on the connection.
Hi @mattdeluco,
Are you trying to debug the import side of your flow? Is there data to import? We just show the information in the debug mode that the application provides to us. If it's a successfully run flow, but you're expecting an import to happen and it didn't, there is most likely an issue in how you currently have the flow configured. To get this resolved for you quickly, could you please create a support ticket on this?
