In this flow i have added two hooks, while using one hook(pre map) it is working but while using both pre and post map the data is ignored. Why?
I've moved your post to the Troubleshoot custom flows section for more visibility!
@deeptismitabehera is it working when you actually run the flow and just not working in preview?
@tylerlamparter-Tyler-Lamparter" rel="nofollow noreferrer">Tyler Lamparter
No its ignoring the data while running.
@deeptismitabehera I would suggest opening a support ticket in that case. You can open one by going under help on the left side of IO.
