Hello Everyone
I am trying to import order as cash sale but i am getting below error
Integration Apps- Amazon-seller central
Error details
Failed to create, update/transform record because Infinite loop is detected in the client script.
Code-infinite_loop_detected
Source-Post submit SuiteScript hook
Can you please help me how to resolve the error.
Hi,
This is just my initial hunch but it could have something to do with how the shipping address on the incoming orders and the addresses on the existing customer records in NS do not match.
Here is what you can try:
- Go to mapping
- Check the Mapping "Shipping Address Country"
- Click on the gear icon
- Can you make sure that the "Use this field for NetSuite record initialization" is NOT checked? If it is checked, uncheck it.
- Retry the error, or re-import the order.
If the error persists, please create a ticket so we can check further.
Hello Richel,
Yes, it worked. Thank you so much for your help.
Hi,
You’re very welcome! I’m glad to hear it worked. Don’t hesitate to reach out if you need anything else. Take care!
