Hi.
could you help me please, To fix the following issue.By the way the tax code and subsidiary are correct.
Failed to add Amazon Order# xxxxxx. Failed to save record because Invalid tax code reference key xxx for subsidiary xx.
thanks.
Hi.
thanks.
That error message is pretty clear. Are you certain that the subsidiary noted in the error message is assigned to that tax code record? If it for sure is, then you may want to open a support ticket.
Thanks Justin.
I believe that the location, tax code, and customer all have the same subsidiary, so everything is placed right. However, when I tried to resolve the error or run the flow again, the same error occurred and there were no updates in Netsuite. It seems that there may be an issue that needs further investigation.
Please share what the solution is once you get it resolved. Good luck!
After a lot of investigations, that error was related to missing Celigo bundle update.Once the update pushed the issue is fixed.
Thanks for the update! Glad you got it resolved.
You are welcome Justin
This issue has been fixed now with the latest bundle update. If the issue persists please raise a support ticket and we will look into it.
