Hello team,
Flow Name- FBA order flow
Can we change the logic so it won't try to match directly with netsuite sku? but always go by what I configure in the "Celigo eTail Item Alias" mapping?
Hi Swapnil,
Hope you're doing well!
For the FBA order flow — just wanted to check if this will apply to all of your items in NetSuite. If so, you might want to take a look at your Item Lookup mapping and update the Search Record Type to use Celigo eTail Item Alias. Also, try setting the available filters to use Name.
If you run into any errors along the way, it’s probably best to reach out to the support team by creating a support ticket — they’ll be able to help troubleshoot further. Thanks
Hello Jacque,
Thank you for your suggestion. I have configured it, and it's working now. Thanks again for your help!
