Hello,
We're implementing this add-on and I notice that it's still using the SP-API Fulfillment Inbound API v0, which I believe is still the old MWS API but just exposed in SP-API. Is this correct? This is a deprecated API and I'm wondering if there is a date when v2024-03-20 will be available for use, or a product roadmap outlining the migration to the new API.
Also, it appears that this solution fully supports customers using Amazon partnered carriers but seems to be inadequate for non-partnered shippers (we use our own). There isn't a way to retrieve the ASN number (a limitation of this API), upload case dimension (API only supports partner shippers), and retrieve labels via this integration, this all still has to be done from the Seller Central portal. Is this correct as well or am I missing something? We can upload our shipment plan and create our child orders just fine, but after that we have to go into the portal and convert the orders from API orders to be able to update container dimensions and print labels.
I realize this sounds like more of a rant, it's not. I really just want to make sure that I'm not missing something. I'm not able to find any information regarding this, only going by what I'm experiencing as we implement and test.
Thanks!
