I have an http connection to an app (First Dollar) and need to use GraphQL to import. Is there a sample for how the request should look? This is my first time using GraphQL so I am not familiar with how to do it in Celigo (but do have it working in Postman).
mutation CreateOrganization($input: CreateOrganizationInput!) {
createOrganization(input: $input) {
... on CreateOrganizationResult {
organization {
id
name
... on BadRequestError {
code
message
... on InternalServerError {
code
message
"input":{
"name":"Clearwater Testing"
Hi @daveguderian,
Having a working GraphQL call in Postman is a great starting point!
In Integrator.io, we have a GraphQL connector (the credentials part work the same as an HTTP connection)
When you create import/export steps with a GraphQL connection the form is a little different so it plays nice with GraphQL. Specifically, it has a "Query" section and a "Variables" section like you see in Postman.
We have some great knowledge base articles that should help guide you along. But you're probably most of the way there already.
https://docs.celigo.com/hc/en-us/articles/4843857027227-Set-up-a-connection-to-a-GraphQL-endpoint
https://docs.celigo.com/hc/en-us/articles/6177684981787-Build-GraphQL-queries
I'm adding a couple of screenshots for visual reference of Postman UI vs the integrator UI for GraphQL calls
