Uninstall an individual Flow
We need to remove and install one of our flows in Celigo. Is there any way to remove an individual flow and reinstall it. The only thing we have seen is to remove our entire Integration and then reinstall all the flows.
Hi @ericroelofs,
I've moved this to our main Troubleshooting area, to ensure visibility. Are you using a flow you created yourself? If so, would detaching the flow from the integration work? Are you just trying to remove the flow from an integration and re-add it? If so, I'm not sure how that would help you, as you can always turn off the flow. I may not be understanding correctly, so if that doesn't meet your needs, could you expand on what you're trying to do by "removing and reinstalling" the flow?
