Trouble Deleting Multi-Instance Flow: Can’t Disable or Remove Instances
I’m having trouble deleting a Multi-Instance Flow and its related instances. The system tells me I need to disable the instance flow first, but I’m not able to disable it at all.
Has anyone run into this issue or know what might cause the disable option to be blocked?
@nuriensing - Have you disabled the main base flow also ? That should be enabled in order to make any change in the instances (including enabling/disabling it).
Enabling the main base flow solved the issue. Once it was active, I was able to disable the instances and delete them without any problems.
Thanks!
