Remove unused (unwanted) sources in Celigo
Hi,
Are there any pre-built integrations to remove unnecessary resources in Celigo?
We have a lot of unused connections, imports, exports, scripts, etc in Celigo. To utilize the Celigo platform, I am just seeking any approaches to remove those within the Celigo platform, especially those that are not linked to existing integrations.
Hi,
For deleting scripts on the marketplace, you can install the Script cleanup & deduplication tool.
For flows, I think @tylerlamparter has a template for this—but ideally this should be a native Celigo feature :grinning_face_with_smiling_eyes:
Hi Nuri, Thanks.
I would like to build an integration by using integrator APIs to remove all unused sources, such as connections, imports, exports, and scripts which are not linked to an integration.
Just seeked an info whether someone has already done that.
That's exactly what this flow in the marketplace does: Celigo integrator.io: Integration Platform-as-a-Service (iPaaS)
Ah, I tried to find that on the EU Marketplace, but it’s not there. It looks like the ‘Delete nondependent integrator.io resources’ template is only available on the US Marketplace.
I must have missed publishing to EU as well, but it's there now.
