Sublist error
I have a Celigo flow which is to create Bill payment record in NetSuite using NetSuite search. The flow was working initially as I have tested it for several records now we havn't change anything and we are observing error. The error persist even if there is a Bill record present on a sublist to attach on the Bill Payment for related vendor.
error -
Failed to create, update/transform record because You have attempted an invalid sublist or line item operation. You are either trying to access a field on a non-existent line or you are trying to add or remove lines from a static sublist. Tip: Please make sure that all the line items that you're trying to use exist on the record.
@oggsolutions Moving this post to the Troubleshoot custom flows topic for a better reach. Just wanted to confirm if you are facing this issue in a custom flow or is the issue with a flow in an Integration App. If the issue is with a flow in the Integration App, request you to provide the flow name and the Integration App name in which this issue occurs so that we can direct it to the relevant team and ask them to help you resolve this issue.
