Slowness When Cloning Import
I am seeing quite a delay in a cloned import showing up and being available to use in a flow. I cloned an import over an hour ago and am still not seeing it when I go to try to use it in the flow. Is this a known issue, or should I log a ticket?
There should not be any delays here. Try editing the cloned import, and save it again, and then see if it shows up. If it does not show up still, then def log a ticket.
Hey Scott - I checked again after I saw your message and they were available to use in the flow (I didn't end up needing to edit). That said, they did take several hours to appear. If I see it again I'll be sure to log a ticket and see if I can reproduce it with support! Thanks as always!
