Dashboard Glitch
We're seeing that the flows have been appearing as "stuck" since 4/9 and have remained in the same status since then.
Out of the 8 flows, 2 are scheduled flows that were genuinely stuck. We had to cancel and backdate them to pick up data correctly.
The remaining 6 flows are real-time flow. While they appear to be stuck on the dashboard, the run history confirms they are still actively processing data. I'm attaching some screengrabs for reference.
Scheduled flows can be canceled and cleared manually, but how do we handle the real-time flows? When we open them, there’s no indication that they are actually stuck.
Is this a temporary dashboard glitch?
Message me your flow id
Sure!
Hi Tyler,
The flows are still on the dashboard. Do we need to raise a support ticket for this?
Yeah you should raise a support ticket so they can clear this for you.
