Shopify product collection
How can i sync from Netsuite to Shopify the product collection data type?
We use integration Shopify - Netsuite, not the tamplate.
Hi Gianluca,
We have a flow "NetSuite items to Shopify collects" as part of "Shopify - NetSuite" template available in the marketplace, it allows to sync NetSuite items as Shopify collects .
Thanks!
Hi Vani. Thanks but we use integration not the tamplate. For use template i think we need an extention for the subscrition.
Hi Gianluca,
As long as you are connecting to the same Shopify and NetSuite instances, you should be able to use the template without consuming additional endpoints. Currently we do not support this flow as part of the IA.
Thanks!
Hi Vani.
Thanks for the information
Hi Vani
I use "NetSuite items to Shopify collects" to add values from NS to SHP and work fine.
I would use same flow (CLONE) but for remove association from product and collection.
I set "Removes a product from a collection" in import as below.
But when i run the flow receive this error!!!
"errors": "Not Found"
The association exist on Shopify!!
Hi Gianluca,
I suggest that you submit a support ticket so that our team can look at the flow and help resolve the errors.
Thanks!
