Is there a way to limit the Shopify payout to run for a single day's payouts? We would like to test it when we turn it on the first time as the shopify site has been live for a couple of months
i know you can customize the start date time when you run the flow the first time but this will not limit the payouts to a single date
You can use an input filter to consider only a single payout (for the payout you want to sync). For this, please use the below steps:
First, get the Payout Id from Shopify. Access the list of Payouts using URL: https://.myshopify.com/admin/payments/payouts and open specific payout to get the ID in the URL. Then,
1. Open the Shopify - NetSuite Integration App and select 'Payout' section. Click on the flow 'Shopify Payout to NetSuite Payout Custom Record'
2. Click on the '+' icon under the bubble 'Post Payout Custom Records to NetSuite' and then open the input filter using the 'filter' option (see screenshot below and note this is shown once you click on + icon)
4. Run the flow 'Shopify Payout to NetSuite Payout Custom Record' to sync the payout.
Note: Please note that these entire changes have to be revoked when you want to run the flow again to sync more payouts. Also, make sure to select the actual starting date.
