Shopify order edit fails with customer -1 although valid entity is mapped
Flow: Shopify order to NetSuite order (cash sale or sales order)
I am encountering an error when trying to edit an order in NetSuite using the standard Celigo Shopify-NetSuite integration. The order creation flow works perfectly, and I have verified that all relevant settings are configured correctly. Could you help me understand what might be causing this issue with the edit sync?
Thanks,
Dipali
Below is the order Edit request
importing record:
{"nlobjRecordType":"salesorder","nlobjFieldIds":{"celigo_recordmode_dynamic":"true","entity":2823849,"subsidiary":2,"orderstatus":"Pending Fulfillment","billaddr1":"7 Meadow Vale Close","billaddr2":null,"billaddressee":"Victoria Grief","billattention":null,"billcity":"YARM","billstate":"ENG","billzip":"TS15 9WG","billphone":"+447736765264","billcountry":"GB","shipaddr1":"7 Meadow Vale Close","shipaddr2":null,"shipaddressee":"Victoria Grief","shipattention":null,"shipcity":"YARM","shipstate":"ENG","shipzip":"TS15 9WG","shipphone":"+447736765264","shipcountry":"GB","shipmethod":10472,"custbody_celigo_shopify_giftcard_id":"","custbody_celigo_etail_risk_rating":"","custbody_celigo_etail_risk_analysis":"","custbody_celigo_shpfy_transaction_ids":"8784302375168,8784309649664","custbody_celigo_shpfy_updatedtime":"2026-09-28T10:20:45-04:00","custbody_celigo_etail_channel":"Shopify","custbody_celigo_etail_order_id":"7215516680448","custbody_celigo_shopify_order_no":"1003","custbody_celigo_shopify_discountcode":"","otherrefnum":"#1003","custbody_celigo_etail_transaction_ids":"rhbQDow9WNXRH3ZlsIn5ypCZI,#1003.1","custbody_celigo_shpfy_ispickup":"","currency":1,"custbody_eb_shopify_tags":"","custbody_eb_customer_tags":"","memo":"crc-test-r10ey0i9","terms":9,"department":1,"class":24,"custbody_cseg_sales_type":4,"custbody_shopify_notes":null,"custbody42":1,"celigo_ignore_mandatory_fields":"true","trandate":"09/28/2026 10:17:59 pm","celigo_write_log":"true","celigo_replaceAllLines_item":"true","celigo_persist_new_line_insertion_order":"true","internalid":6848857,"custbody_celigo_shopify_store":201,"shippingcost":0,"externalid":"SHPF-86161850624-7215516680448","custbody_celigo_pre_order_submit_data":"{"items":{"16968102936832":{"taxAmount":"0","taxrate1":0,"taxcode":11},"16968102969600":{"taxAmount":"0","taxrate1":0,"taxcode":11}},"taxes_included":true}","custbody_celigo_etail_bill_exp":true},"nlobjSublistIds":{"item":{"lines":[{"quantity":2,"price":-1,"rate":"140.00","custcol_celigo_etail_order_line_id":"16968102936832","custcol_celigo_etail_fulfillment_serv":"manual","class":24,"department":1,"custcol_customer_type":1,"custcol_sales_channel":1,"line":"1","taxAmount":"0","custcol_celigo_etail_order_line_tax":"0"},{"quantity":1,"price":-1,"rate":"0.00","custcol_celigo_etail_order_line_id":"16968102969600","custcol_celigo_etail_fulfillment_serv":"manual","class":24,"department":1,"custcol_customer_type":1,"custcol_sales_channel":1,"line":"7","taxAmount":"0","custcol_celigo_etail_order_line_tax":"0"}]}},"documentIndex":0,"eTailCache":{"preSubmitOrderTaxData":{"items":{"16968102936832":{"taxAmount":"0","taxrate1":0,"taxcode":11},"16968102969600":{"taxAmount":"0","taxrate1":0,"taxcode":11}},"taxes_included":true},"preSubmitVarianceData":{"orderTotal":280,"shippingTotal":0,"taxTotal":0,"discountTotal":0},"reSubmittableNegativeLines":{}},"INTEGRATOR_IO_MAPPER":true}
nlapi calls registered for $R:
r = nlapiLoadRecord("salesorder", 6848857, {"recordmode":"dynamic"});
r.setFieldValue("subsidiary", 2);
r.setFieldText("orderstatus", "Pending Fulfillment");
r.setFieldValue("billaddr1", "7 Meadow Vale Close");
r.setFieldValue("billaddr2", null);
r.setFieldValue("billaddressee", "Victoria Grief");
r.setFieldValue("billattention", null);
r.setFieldValue("billcity", "YARM");
r.setFieldValue("billstate", "ENG");
r.setFieldValue("billzip", "TS15 9WG");
r.setFieldValue("billphone", "+447736765264");
r.setFieldValue("billcountry", "GB");
r.setFieldValue("shipaddr1", "7 Meadow Vale Close");
r.setFieldValue("shipaddr2", null);
r.setFieldValue("shipaddressee", "Victoria Grief");
r.setFieldValue("shipattention", null);
r.setFieldValue("shipcity", "YARM");
r.setFieldValue("shipstate", "ENG");
r.setFieldValue("shipzip", "TS15 9WG");
r.setFieldValue("shipphone", "+447736765264");
r.setFieldValue("shipcountry", "GB");
r.setFieldValue("shipmethod", 10472);
r.setFieldValue("custbody_celigo_shopify_giftcard_id", null);
r.setFieldValue("custbody_celigo_etail_risk_rating", null);
r.setFieldValue("custbody_celigo_etail_risk_analysis", null);
r.setFieldValue("custbody_celigo_shpfy_transaction_ids", "8784302375168,8784309649664");
r.setFieldValue("custbody_celigo_shpfy_updatedtime", "2026-09-28T10:20:45-04:00");
r.setFieldText("custbody_celigo_etail_channel", "Shopify");
r.setFieldValue("custbody_celigo_etail_order_id", "7215516680448");
r.setFieldValue("custbody_celigo_shopify_order_no", "1003");
r.setFieldValue("custbody_celigo_shopify_discountcode", null);
r.setFieldValue("otherrefnum", "#1003");
r.setFieldValue("custbody_celigo_etail_transaction_ids", "rhbQDow9WNXRH3ZlsIn5ypCZI,#1003.1");
r.setFieldValue("custbody_celigo_shpfy_ispickup", "F");
r.setFieldValue("currency", 1);
r.setFieldValue("custbody_eb_shopify_tags", null);
r.setFieldValue("custbody_eb_customer_tags", null);
r.setFieldValue("memo", "crc-test-r10ey0i9");
r.setFieldValue("terms", 9);
r.setFieldValue("department", 1);
r.setFieldValue("class", 24);
r.setFieldValue("custbody_cseg_sales_type", 4);
r.setFieldValue("custbody_shopify_notes", null);
r.setFieldValue("custbody42", 1);
r.setFieldValue("trandate", "09/28/2026");
r.setFieldValue("custbody_celigo_shopify_store", 201);
r.setFieldValue("shippingcost", 0);
r.setFieldValue("externalid", "SHPF-86161850624-7215516680448");
r.setFieldValue("custbody_celigo_pre_order_submit_data", "{"items":{"16968102936832":{"taxAmount":"0","taxrate1":0,"taxcode":11},"16968102969600":{"taxAmount":"0","taxrate1":0,"taxcode":11}},"taxes_included":true}");
r.setFieldValue("custbody_celigo_etail_bill_exp", "T");
r.selectLineItem("item", 1);
r.setCurrentLineItemValue("item", "quantity", 2);
r.setCurrentLineItemValue("item", "price", -1);
r.setCurrentLineItemValue("item", "rate", "140.00");
r.setCurrentLineItemValue("item", "custcol_celigo_etail_order_line_id", "16968102936832");
r.setCurrentLineItemValue("item", "custcol_celigo_etail_fulfillment_serv", "manual");
r.setCurrentLineItemValue("item", "class", 24);
r.setCurrentLineItemValue("item", "department", 1);
r.setCurrentLineItemValue("item", "custcol_customer_type", 1);
r.setCurrentLineItemValue("item", "custcol_sales_channel", 1);
r.setCurrentLineItemValue("item", "line", "1");
r.setCurrentLineItemValue("item", "custcol_celigo_etail_order_line_tax", "0");
r.commitLineItem("item");
r.selectLineItem("item", 2);
r.setCurrentLineItemValue("item", "quantity", 1);
r.setCurrentLineItemValue("item", "rate", "0.00");
r.setCurrentLineItemValue("item", "custcol_celigo_etail_order_line_id", "16968102969600");
r.setCurrentLineItemValue("item", "line", "7");
nlapiSubmitRecord(r, false, true);
Hi there! Just wanted to put the resolution back here in case anyone encounters the same. :slight_smile: As discussed in the support ticket, a hard-coded Subsidiary mapping didn’t account for edited orders and caused the issue. Updating it to a conditional handlebar expression resolved the problem.
