I'm working on custom flows for Shopify, and so far, I have been able to create GraphQL flows for all my needs.
The only area I'm having an issue with, is Shopify Payments. When I try query a shopifyPaymentsAccount, I'm getting permission issues:
"message": "Access denied for shopifyPaymentsAccount field. Required access: the read_shopify_payments or the read_shopify_payments_accounts access scope.",
I've been trying to troubleshoot this with my customer (they own the Shopify store), but in the end, I realized that since I'm connecting to Shopify using the Integrator.io Shopify App, it's the App that is probably missing the right permissions.
In investigating the App Permissions in Shopify, I do see this:
Thanks for the answer, Chris. To which user should they grant this permission? In my mind, the Integrator.io Shopify App needs to have this permission, and I think this is out of my control.
My user itself is a super user with all these permissions. So I'm still stuck.
Ah I see what you mean. So for my Shopify GraphQL connection, i created a custom app in my Shopify Admin and manually set all the API permissions under Configuration. Once you install it, you get an API access token. In Celigo, the Shopify connection auth type is not OAuth 2.0 but Token and I enter the token I got from Shopify. So it doesn’t utilize the Integrator.io Shopify app at all. I don’t know if it’s possible to edit the API permissions for that.
Chris... this is exactly what I needed to know. We definitely cannot change the permissions for the Integrator.io app, Celigo would need to do that (@tylerlamparter , could you chime in if possible?)
But knowing that there's a possibility of creating a "Custom App" in Shopify and still use the Shopify Connection in Celigo, that's gold!
Really appreciate your input on this. From what I see now, the customer did contact their Shopify specialist in trying to troubleshoot this, and apparently their Shopify specialists created a Custom App. But they never set up the connection in Celigo with such access.
Thanks!
If Tyler doesn't chime in (as this needs to be changed in the Integrator.io App), I'll mark your answer as the best solution for this topic.
I suspect we have this in the roadmap to add in, but am waiting for some internal confirmations. With any app change, we have to go through Shopify's approval process so it can take some time to make any changes like this.
The custom app is a great approach in the meantime.
Thanks for sharing this request Marcelo. We will be updating the Shopify connection to include these scopes, subject to Shopify’s approval. We’ll share updates as we make progress.
In the updated scope list, Returns is also included. We will make sure to support both read_returns and write_returns. I’ll keep you posted as the scope gets added and enabled.
