Replace connections on imports and exports
Hey everyone — I built a new helper flow that makes it way easier to migrate imports and exports from one connection to another.
Why I built this:
We recently updated the Shopify connector so you can now select GraphQL directly in the native connection.
If you originally built your Shopify integrations using the generic GraphQL connector, you can now move everything over to the native Shopify connector — and this flow helps you do it fast.
How it works:
  • Pick the old connection you want to replace (a Shopify connection that used the generic GraphQL connector).
  • Pick the new connection you want to move everything to (your new native Shopify connection).
  • Run the flow — it’ll automatically update all the imports and exports tied to the old connection.
Why it matters:
  • Saves you time — no need to manually edit each import/export.
  • Reduces endpoint usage — all Shopify connections will now be counted under the Shopify endpoint instead of the Shopify endpoint and Generic GraphQL endpoint.
Flow name:
Replace connection on imports and exports (available now in the Marketplace)
Hope this saves you some time! Let me know if you have any questions.
