I wanted to check with the community before submitting an idea for this (its pretty simple, but would make cleanup efforts much easier).
Is there a way to see which imports/exports are not being used, or does it require going import by import (or export by export) and clicking the "Used By" button?
@daveguderian I just published a template to the marketplace that will go through your account and delete all of these nondependent IO resources. If you don't actually want to delete them, then you could swap out the delete import with an S3 bucket or other import.
https://integrator.io/marketplace/installTemplate/preview/663a41b80df29dc77ec70618
