Hello,
How do you remove a schedule from a flow?
Felipe
Hello,
Felipe
To remove a schedule from a flow:
You can also turn off the toggle switch in the flow-level task bar if you’re in the flow itself. If you’re in the integration level (clicked tile, now viewing Flows), you can turn the flow off with the switch in the Off/On column.
