Q: I would like to schedule a flow and then trigger another flow to run upon its completion. Is there a way to accomplish that in integrator.io?
A: Yes. This is an important feature for many integration requirements.
Open a flow in Flow Builder and click the Settings button (gear icon) at the top right. In the Settings pane, select another flow from the list to be the Next integration flow.
The only restriction is a logical one: a realtime flow cannot be scheduled next.
For a demonstration in the legacy user interface, see this quick video.
