I have registered an existing connection within a new integration, but am not seeing it when I try to use it in a flow. Im trying to figure out if I missed a step?
Registered Integrator.io Connection
Not seeing the connection when I try to use it
Hey Dave,
Maybe try changing the application from HTTPs universal connector to the integrator endpoint. The connection might be under there.
That was it Nate! I knew there was something I was missing! Thanks again for the help!
