I am trying to make an Oath 2.0 connection and running into the below error, but not sure which field is actually the root cause of the error. Any help is appreciated!
Connection:
@daveguderian had you initially saved this with a different setup? Can you make a new connection and new iClient?
I was playing around with it today and switched the Grant Type from Client Credentials to Authorization code based on not seeing the field Youssef referenced.
I do have this working in Postman. Would it be be helpful for me to post screenshots from Postman?
Tyler - I rebuilt a second Oath Client and still received this error when trying to save the connection.
@daveguderian can you make a support ticket?
