FAQ: How do I delete connections
You can't currently delete a connection directly from the Flow Builder because connections can be used in multiple integrations, so you'll need to go to the Connections list.
Go to Tools & Resources > Connections. On the connection you want to delete, click the Actions drop-down > Delete connection.
Not seeing the delete option, what am I missing?
@jonahgoska,
It's likely that the connection belongs to an integration app, and we restrict the deletion of primary connections that belong to integration applications.
Nope - I have an unused and offline connection and there is still no "delete" option. Please help
It's not possible to remove connections from IAs.
@vincentnero
You cannot currently delete a connection from the connections tab of an integration tile as well.
Go to Resources > Connections . On the connection you want to delete, click the Actions drop-down > Delete connection .
