PROBLEM REPORT: Installing a NetSuite template
We’ve detected an issue with installing a template that has NetSuite as an endpoint.
After the setup asks you to configure your NetSuite connection, it then includes logic to connect to your account and verify whether you have already installed the integrator.io NetSuite bundle (20038).
If the bundle is installed, you should see a confirmation icon on the setup page, or it should proceed to install the template if you’re at the last step.
At present, the setup stops at the step Integrator bundle, offering you an “Install” link. You must click that link to continue and force the setup to verify the NetSuite bundle – even if it’s already installed.
We’ve prioritized fixing this issue and hope to update you with a resolution in an upcoming integrator.io release.
