1 NetSuite Instance (3 Shopify Stores same NetSuite)
- Shopify Store #1
- Shopify Store #2
- Shopify Store #3
Different customer base or at least that is the intention behind it. Can't really stop them from buying in at least 2 stores.
Issue:
If you place an order on Shopify Store #2 but the customer already exists in NetSuite because they placed an order before in Shopify #1 the flow fails because of the email address or something that ties back to that NetSuite customer.
Any way around this? Best solution?
Hi @jcromualdo,
You can try to adjust your identification logic for your customer sync, but this is a more advanced modification so if this isn't something you're familiar with, we suggest you file a support ticket so that they can help you with this.
