Management Reporting Automation (Netsuite Financials)
Say goodbye to tedious manual exports and spreadsheet chaos! With Celigo’s prebuilt NetSuite-Google Sheets integration, our data refreshes automatically every day, eliminating the need for manual exports, pivot table gymnastics, and endless email attachments. Now, we simply share a Google Sheets link, giving management instant access to up-to-date KPIs and pivots—no hassle, no delays, just fresh data at their fingertips. It’s automation that saves us countless hours and keeps us focused on insights, not busywork.
This flow is designed to export transaction data from NetSuite and update or append it to a Google Sheets spreadsheet. The import uses a preMap hook to perform a lookup operation before mapping the data and a postMap hook to merge updates with existing rows. These hooks allow for custom logic to be applied during the import process. The data is mapped from the source fields in NetSuite to the corresponding columns in the Google Sheets spreadsheet. Overall, this flow automates the process of exporting transaction data from NetSuite and updating or appending it to a Google Sheets spreadsheet, providing a seamless integration between the two systems.
