Loading indicator keeps showing after a flow step has already loaded
Sometimes on eu.integrator.io, when opening a flow step, the step itself loads correctly, but the loading box at the top keeps showing and only disappears after around +-30 seconds.
I'm not sure what causes this, but I think the loading experience could be improved.
My suggestion would be:
  • If the page content has not loaded yet, keep showing the normal loading box.
  • If the flow step is already visible and only some background data is still loading, replace the large loading box with a smaller loading indicator somewhere at the top or bottom of the page.
  • If possible, show in small text what is still loading.
  • Alternatively, add a "View loading details" button or link. Clicking it could show which components, requests, or data are still being loaded.
That way, the user can continue working with the flow step while still being aware that something is loading in the background. It would also make it easier to understand what is taking longer instead of making it look like the entire step is still loading.
