Bug: Search/filter function inside flow step errors view does not handle large error lists correctly
The search function inside the flow step errors view seems a bit buggy and difficult to use.
  1. When I start typing in the search box, it immediately starts loading and adds a grey overlay in the background. The experience feels a bit jumpy and not very smooth. It may be better if the search field used a dropdown-style result box, similar to the search experience in this community, where suggestions/results appear below the input and the user can click on them.
  2. I have a flow step with 1,000+ errors and I am trying to filter duplicate errors. However, when I search, I get the error shown in this screenshot:
    The search box also stays open and keeps showing the loading/searching state. The only way I can close it is by pressing Escape.
Could you please check this behavior? It seems like the search may not be handling large error lists properly, and the UI does not recover cleanly after the search fails.
Hi @nuriensing Thank you for reporting this. Could you share how long was the search text you entered when the error occurred?
Failed to save record because Record has been changed
Thanks Nuri! We've identified the issue and will roll out the bug fix soon.
Thanks for the quick update!
