Does anyone have this problem on EU? It seems not working
And if it loads the errors are not showing, its shows everything as a success. Here is a screenshot where I should have errors:
Yes we are also getting this on our account - we are getting success responses back on flows so it seems to be the front end only, so far
Probably an update happening.
I have just been able to login to IO on the EU DC
it has finally just loaded for me - took a while. But none of the links to errors on the home screen are loading.
The run console/run history also isn’t loading when I go into a flow
Attached a screenshot, doesn’t show a lot but this is the run history currently, and run console isn’t even showing at all on the screen
It is working for me again.
Yes same, seems to be fine now
