Known issue: NetSuite item groups importing with incorrect line prices and totals (Shopify – NetSuite and other NetSuite integration apps)
Affects: Shopify – NetSuite integration app customers who have Settings > General > “Manage NetSuite item group using” set to Member component or Master component. Custom (DIY) flows might also be affected if they write a custom column value to an item group header line and read it back later.
What’s happening
Starting with the NetSuite October 2026 monthly update, NetSuite changed how it handles transaction column custom fields on item group lines when a record is saved by a script. This change was not announced in advance.
If the field’s “Store With Item Groups” option is not enabled, NetSuite now copies the value onto each member line and clears it from the group header line. Previously, the value stayed on the header.
Our integration app relies on the header line for internal processing in hooks to redistribute the Shopify selling price across the item group’s member lines after the order is created. Because that ID is now cleared from the header, that step no longer runs.
Symptoms you may see
  • Sales orders created from Shopify where item group member lines show their NetSuite list / base price instead of the Shopify selling price, so the NetSuite total does not match Shopify.
  • The eTail Order Line ID appearing on every member line (without the usual _memberItem_N / _masterItem_N suffix) and blank on the group header.
What we’re doing
  • NetSuite Support has logged a U2 defect for the case we raised (Case #7141990).
  • We have escalated this with NetSuite Support, and they have confirmed their engineers are working on it.
In the meantime
  • Until this is resolved, we recommend refraining from importing orders with item groups, if possible.
  • If you have already imported affected orders, please do not fulfill, bill, or otherwise process them in NetSuite yet. These orders will need to be deleted and re-imported once the fix is in place, and downstream transactions will block that.
  • Affected orders that have already been imported will need to be deleted and re-imported after the resolution to correct the totals.
  • If you have already imported a large number of affected orders, we are developing a mass delete script that we will share so you can bulk delete those orders and re-import them once this is resolved.
  • There is no immediate workaround available for integration apps at this time.
DIY flows that might be affected
You may be impacted if your flow sets a transaction column custom field on an item group header line and depends on that value staying there (for example, to match the line on a later update, or a NetSuite hook/script that reads it).
For DIY flows, the impact depends on your specific use case. Please review your flows that touch item groups, and if you see unexpected behavior, raise it directly with NetSuite Support.
