I'm encountering an issue while upserting an item in NetSuite where I need to set the subsidiary ID. My goal is to assign a specific subsidiary (other than the head subsidiary) to an item, but despite my efforts, it always defaults to the head subsidiary, which is ID "1".
I mapped it like following:
And I also tried different variations like: hardcoded, lookup etc. However, when I review the debugger, it seems that Celigo is interpreting my input as an array (e.g., `[13]`) instead of a single integer value:
Interestingly, I have a similar flow step for creating opportunities where this issue does not occur, and the subsidiary ID is set correctly as integer.
I'm seeking insights into two aspects: 1. Why is Celigo interpreting the subsidiary ID as an array in this case? 2. How can I successfully set the subsidiary to another ID like for example "13" for an item upsert?
Hi @nuriensing3844-Nuri-Ensing" rel="nofollow noreferrer">Nuri Ensing, Regarding your two queries, for Item record subsidiary is a multi-select field, that's the reason we need to submit it as an array. but for transaction records, it's a select-type field instead of a multi-select, that's the reason we submit it as string "13".
Not sure why you are not able to submit the 13 value for the item record subsidiary. ideally, it should work. this is the right way to submit the value for the subsidiary for the item record. I don't see any issues with it. are you seeing any kind of errors in the dashboard?
Hi, Thank you both for your insights and suggestions.
@muneswarathotakura I appreciate your explanation regarding the need to submit the subsidiary as an array for item records and as a string for transaction records. You're correct, and that aligns with my understanding as well. I was puzzled about why submitting the value "13" for the item record subsidiary wasn't working as expected. However, it turns out there was an external factor at play. A consultant informed me yesterday that there was a script running in the background in NetSuite which was altering the subsidiary. This means that while Celigo was sending the data correctly, it was being modified within NetSuite. Your input was invaluable in helping me to troubleshoot this issue.
@steveklett Thank you for highlighting those points. I checked, and all the aspects you mentioned are in order. The issue, as I previously noted, turned out to be an internal script running in NetSuite, which was affecting the subsidiary data after Celigo sent it correctly.
Regarding the tagging issue, I believe you see my name multiple times because of my history with multiple accounts. My company changes and different email addresses have led to the creation of these additional accounts. I hope this clears up any confusion.
Again, I'm thanks for your assistance and the time you both took to help resolve this matter :-)
