How to 'Close' a transaction in NetSuite
On some transactions in NetSuite is a 'Close' button. A Celigo resource once said to me, if you can do it in the UI then we can do it with Integrator.io. So I'm wondering how to close the transaction via .io? Essentially when you click the close button in the UI, it closes each line on the trx. I know there is an option 'Items : Closed' to map, but I would like to be able to send a command to do the same thing as the 'Close' button and have it close all of the lines automatically. Is there a Celigo_nlobj_ command that can be used to do this?
Thanks for writing in about this need. I just checked with our NetSuite experts on this. As of now, there is no shortcut mapping to close an entire order. You will have to map the "close" field mapping for each of the lines that you would like to close. integrator.io uses NetSuite APIs to achieve what you can do directly in the NetSuite API, but we don't have anything to mimic button clicks from the UI. If you'd like, we can move this post to our IO enhancements community topic, so that others can vote on it.
