The fields in Zoho CRM map perfectly to Netsuite if it's a standard field with text or numbers, but I need to map over fields that have a lookup value on the Zoho form.
Is there a way to easily do this? I have four fields with this issue.
Hi @rodneyveach,
It looks like you were able to get the answer you needed through Support. If you have a minute to post an example of what you successfully mapped so that other users who search the Community can benefit from it, we really appreciate it.
Thanks,
Kate
