Using the ‘keypairs’ Field in Celigo Forms Sourced from NetSuite
Is it possible to create a ‘keypairs’ field like the one in the Shopify Integration App that sources its values from a NetSuite saved search?
Yes
Or you can use optionsMap field type in an example like this if you need more than 2 columns:
  "fieldMap": {
    "salesforceAccountType_map_netsuiteCustomerStageAndStatus": {
      "optionsMap": [
          "id": "netsuiteLocation",
          "name": "NetSuite Location",
          "type": "exportSelect",
          "resource": {
            "virtual": {
              "name": "Lookup",
              "_connectionId": "626168f90b6ef816b50c82d7",
              "asynchronous": true,
              "oneToMany": false,
              "netsuite": {
                "type": "restlet",
                "skipGrouping": true,
                "statsOnly": false,
                "restlet": {
                  "recordType": "location",
                  "searchId": "3369",
                  "useSS2Restlets": false
                "distributed": {
                  "useSS2Framework": false
              "distributed": {
                "disabled": false
              "adaptorType": "NetSuiteExport"
          "id": "netsuiteCustomerStage",
          "label": "NetSuite Customer Stage",
          "required": true,
          "type": "select",
          "options": [
              "value": "lead",
              "label": "Lead"
              "value": "prospect",
              "label": "Prospect"
              "value": "customer",
              "label": "Customer"
          "id": "netsuiteCustomerStatus",
          "label": "NetSuite Customer Status",
          "required": false,
          "type": "select",
          "options": [
              "value": "6",
              "label": "Unqualified"
              "value": "7",
              "label": "Qualified Lead"
              "value": "8",
              "label": "In Discussion"
              "value": "9",
              "label": "Identified Decision Makers"
              "value": "10",
              "label": "Proposal"
              "value": "11",
              "label": "In Negotiation"
              "value": "12",
              "label": "Purchasing"
              "value": "13",
              "label": "Closed Won"
              "value": "14",
              "label": "Closed Lost"
              "value": "15",
              "label": "Renewal"
              "value": "16",
              "label": "Lost Customer"
              "value": "17",
              "label": "Qualified Prospect"
      "allowFailures": false,
      "hideLookupAllowFailures": true,
      "title": "Map Salesforce Account Type to NetSuite Customer Stage and Status",
      "tooltip": "",
      "name": "salesforceAccountType_map_netsuiteCustomerStageAndStatus",
      "type": "staticMap"
  "layout": {
    "fields": [
This is amazing, Tyler! Thank you so much. I got it to work.
