I'm trying to transfer my NetSuite - Salesforce IO connection to production in Celigo. For some reason, the consultants we worked with set up 10+ connections between Salesforce - Celigo and Celigo - Netsuite. Is it possible to delete connections so I don't have to set up all of them. I currently don't see a delete option when I click the three dots next to each connection
Hello Anna,
Those IA connections cannot be deleted via UI, but please reach out to the support team, and they can delete those connections from the backend.
Please note that you should not delete the primary connection, which will be needed for the IA setup.
Thanks,
Sushil Patil.
