FAQ: How do I add a custom flow to import data into Shopify?
Regardless of which application you are exporting from, you’ll need to create a private app in your Shopify account in order to import data into Shopify.
  1. Create a custom app in your Shopify account. This is the app that you will connect to with your new Shopify connection.
  2. Copy your API key and password that you’re provided with when creating your private app.
  3. Set up your Shopify connection for your custom flow.
  4. Enter your API key and password into your new Shopify connection.
Another use case for this is if you are using our Shopify-NetSuite integration app and want to add another custom flow to import data into Shopify. In that case, you should not link your custom flow to this integration app, as it is essentially separate from any custom flows that you may be using to integrate with Shopify.
