Export error code : missing webiste
When i check the export preview in the SB of the celigo, In the netsuite to magento product sync the export preview is not available in the export preview
"record": {
    "code": "missing_website",
    "message": "Failed to Export Item #8, Please select at least one website for this item",
    "dataURI": "/app/common/item/item.nl?id=8&compid=7180649_SB1",
    "source": "pre_send_hook_ss",
    "resolved": false,
    "occurredAt": 1765274584777
this is how it shows but in the production it’s working properly without any issue, in the export preview the celigo pull the data from the netsuite
Hi Samson,
Thank you for reaching out. We recommend submitting a support ticket for this issue so that the team can further investigate it.
