Hi,
I have set up a connection to Zoho people's API using HTTP /Oauth 2.0. The connection expires after the access token expiry. The refresh does not seem to be working. I couldn't find an option to configure the refresh token url in HTTP connection setup.
The token request returns the tokens in the following format.
"access_token": "100xxxxxxxxxxxxxxxxxxxxxf",
"refresh_token": "10xxxxxxxxxxxxxxxxxxxxxxb",
"token_type": "Bearer",
"expires_in": 3600
Please advise how this can be solved.
Thanks,
Divya
Can you share screenshots of your full connection setup? For example, what auth type are you using? What grant type? Are you setting any override fields?
Hello Scott,
Thank you for your reply. I already created a support ticket for the issue. I have shared the details with the Technical support representatives. I have included the screenshots for your reference below.
Thanks,
Divya
Hey Divya, i deleted my last response because i was able to sync up with various folks internally, and I also scanned what all our other users are doing when they connect to various zoho apis. Can you try setting the following circled fields, and see if this works? Again, this is what I see other users doing. If this does not work, then please continue working with support, and maybe there is a strange behavior specific to zoho people apis that we need to flush out still.
Important notes:
- I would create a brand new connection just to make sure you start fresh.
- For the authorization url field you might need the "?prompt=consent", but i would try with and without.
- You should of course set the scope field based on what you need (i.e. i did not include a scope in my pics, but you do need this).
- Revoke token url should be removed.
- I see in the docs where they say to use the scheme -> "Zoho-oauthtoken", but I would still try to set the scheme to Bearer and see if that also works.
Hi Scott,
Thank you for the update. I tried creating a new connection with the settings you suggested. Unfortunately I am facing the same issue. It works for the first time as long as the access token is valid ( i.e. 3600 seconds), but once the access token expires, the flow throws an oAuth token invalid error: {"response":{"message":"Error occurred","uri":"/api/forms/P_EmployeeView/records","errors":{"code":7213,"message":"The provided OAuth token is invalid."},"status":1}}
Thanks,
Divya
Hi Divya,
Can you please try to configure the connection as below:
The only thing we missed is to set the 'access_type' query param for the Authorization URL. Please modify that to the one shown in the above screenshot and let us know if you still have any issues.
Thanks.
