I'm having an issue promoting the Salesforce - NetSuite integration app to Production from our sandbox. I have verified that the installed versions of the adapter are the same in both environements and the bundles seem to match. I'm not sure how best to uninstall or downgrade the integrator distibuted adapter in salesforce.
Is there another way to solve for this?
For those who run into this issue, try this link to check the version you're running and then upgrading it for Admins. You can then verify the version again via the clonining process.
In Salesforce, what version are you using for **Integrator Distributed Adapter package: https://login.salesforce.com/packaging/installPackage.apexp?p0=04t8V000001VB6B
I was success in cloning the IA from sandbox -> Production after upgrading this adapter, even though the initial step said to downgrade it.
Best of luck to everyone.
